[Qgis-user] QSIG
Andreas Neumann
a.neumann at carto.net
Wed Jun 27 07:41:29 PDT 2018
QGIS can run offline. Of course you need Internet to download the software.
Certain aspects (optional) require an internet connection. Examples are:
* Base maps (e.g. OpenStreetmap)
* Download of additional plugins from the Repository
* Usage of OGC services (WMS/WFS/WMTS)
* Some plugins may have additional requirements
Regarding ports: the above mentioned services require port 443 and/or 80
(normal web ports). If you want to access databases, there are
additional ports to open (perhaps only on LAN), e.g. for Postgis the
standard port is 5432 - but you can run it on other ports as well.
Regarding proxy: if your web browser requires a proxy, QGIS will have to
use the same proxy as well.
Greetings,
Andreas
Am 27.06.2018 um 16:31 schrieb pompo santos:
> Hello.
> I would like to ask if software QSIG has any special requirements to
> use it or , if is it required to have internet use always ?
> Which internet ports does the application use? Do you have any
> requirements?
> - Is this installation required to bypass firewall or , proxy in a
> company?
> -Do I have to open a special port in firewall?, or , just internet
> port HTTPS?
> Thanks,
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/b5914910/attachment.html>
