[Qgis-user] QGIS 2.18 freeze meanwhile editing
Andreas Neumann
a.neumann at carto.net
Wed Jun 27 23:49:35 PDT 2018
Hi Andrea,
Do you have any plugins enabled? I heard of situations, where a badly
programmed Python plugin could cause such issue.
Can you try starting QGIS without any Python-plugin enabled - see the
--noplugins option at
https://docs.qgis.org/2.18/en/docs/user_manual/introduction/getting_started.html#command-line-options.
I can't promise if it helps to resolve the issue, but if it does, it
would be useful to know which plugin is the culprit.
Greetings,
Andreas
On 2018-06-28 08:32, Andrea Peri wrote:
> Hi,
> I'm using qgis 2.18.
> Every time I goin ediiting on a shapefile , after insert about 10 or 20 features it (the qgis) is freezing. Windows (I use win 7) report me qgis is not responding and I need to kill it and restart.
> I usually do not lost nothing because I know this and after every on insert I save always the shapefile and the project.
> But it is boring.
> I like to know if this is a know issue of qgis or it could be a specific issue of my qgis install.
> I use qgis 2.18.18 (32 bit) but it happened also when I use 2.14 and windows 7 64 bit.
> Many thx.
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180628/512f551a/attachment.html>
