[Qgis-user] QGIS 3 Processing question
Jean-Baptiste Desbas
jb.desbas at gmail.com
Fri Jun 29 07:02:47 PDT 2018
I had the same issue. I had to loop over the output vector layer (child
alg) to feed the sink (main alg). Maybe is not the
simpliest/shortest/fastest, but it works.
Something like that :
o = processing.run(
'qgis:pointsalonglines',
params, context=context, feedback=feedback
)['OUTPUT']
(sink, dest_id) = self.parameterAsSink(
parameters,
self.OUTPUT,
context,
o.fields,
o.wkbType(),
o.sourceCrs()
for f in o.getFeatures()
sink.addFeature(f)
return {'OUTPUT':dest_id}
2018-06-29 9:35 GMT+02:00 Frank Broniewski <hallo at frankbroniewski.com>:
> Hi Nyall,
> thanks a ton for your response. I am well know for making things tricky
> for myself 😃
> Anyway, my testing-algorithm-script is still not working. It runs through,
> but I do not get the expected result loaded into the layer tree. I suppose
> it runs through - the output from the 'qgis:pointsalonglines' is a
> QgsVectorLayer - but after finishing I get nuthink back.
> Here's my complete script: You'll need a temporary polygon layer in a
> projected CRS (I use EPSG:31466) for it to work nicely. Copy & Paste it
> into a new script window and run it. I simply don't find the reason why the
> point result layer isn't loaded into my layer tree ...
> from qgis.PyQt.QtCore import QCoreApplication
> from qgis.core import (QgsApplication,
> QgsProcessing,
> QgsFeatureSink,
> QgsProcessingAlgorithm,
> QgsProcessingParameterFeatureSource,
> QgsProcessingParameterNumber,
> QgsProcessingParameterFeatureSink)
> import processing
> class PolygonCenterline(QgsProcessingAlgorithm):
> INPUT = 'INPUT'
> DISTANCE = 'DISTANCE'
> OUTPUT = 'OUTPUT'
> def tr(self, text):
> return QCoreApplication.translate('Processing', text)
> def createInstance(self):
> return PolygonCenterline()
> def group(self):
> return self.tr('Cartography')
> def groupId(self):
> return 'cartography'
> def name(self):
> return 'polygoncenterline'
> def displayName(self):
> return self.tr('Calculate a polygon centerline')
> def initAlgorithm(self, config=None):
> self.addParameter(
> QgsProcessingParameterFeatureSource(
> self.INPUT,
> self.tr('Vector Polygon Layer'),
> [QgsProcessing.TypeVectorPolygon]
> self.addParameter(
> QgsProcessingParameterNumber(
> self.DISTANCE,
> self.tr('Point distance value'),
> type=QgsProcessingParameterNumber.Double,
> minValue=10.0
> self.addParameter(
> QgsProcessingParameterFeatureSink(
> self.OUTPUT,
> self.tr('Center line')
> def processAlgorithm(self, parameters, context, feedback):
> # qgis:pointsalonglines
> params = {
> 'INPUT': parameters[self.INPUT],
> 'DISTANCE': parameters[self.DISTANCE],
> 'START_OFFSET': 0,
> 'END_OFFSET': 0,
> 'OUTPUT': 'memory:'
> points = processing.run(
> )['OUTPUT']
> return {self.OUTPUT: points}
> -----Ursprüngliche Nachricht-----
> Von: Nyall Dawson <nyall.dawson at gmail.com>
> Gesendet: Freitag, 29. Juni 2018 01:04
> An: Frank Broniewski <hallo at frankbroniewski.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Betreff: Re: [Qgis-user] QGIS 3 Processing question
> On Fri, 29 Jun 2018 at 07:14, Frank Broniewski <hallo at frankbroniewski.com>
> You're making this tricky for yourself! Cut out everything in
> processAlgorithm related to self.INPUT, and just pass the parameter value
> direct to the child algorithm to handle:
> > params = {
> > 'DISTANCE': pt_value,
> > 'START_OFFSET': 0,
> > 'END_OFFSET': 0,
> > 'OUTPUT': 'memory:'
> Nyall
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180629/1967a064/attachment.html>
