[Qgis-user] Grass not found
jehdukeegr at gmail.com
Mon Mar 19 12:57:20 PDT 2018
Thanks William.
I downloaded the update and am still having the same issues.
Other ideas? Thanks guys!
On Mon, Mar 19, 2018 at 1:51 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> I just uploaded an update yesterday that should fix this. At least the
> 2nd error. The first error could be a bigger problem due to my using a
> space in the QGIS app name (there may be a path quoting issue in the GRASS
> internals).
> On Mar 19, 2018, at 2:15 PM, jehdukeegr at gmail.com wrote:
> Hi,
> I'm a new Qgis user. Here are the details:
> Qgis version 3.0.0 (Downloaded 3/17)
> MAC OS 10.12.6 (Sierra)
> I'm trying to use Grass to do some shortest distance network calculations
> and I receive the following error messages:
> /var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_
> 8f76fdc70e874abb92d2ebbbef92c2d3/grassdata/temp_location/PERMANENT:
> /Applications/QGIS: No such file or directory
> and
> The following layers were not correctly generated.
> - /var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_
> 8f76fdc70e874abb92d2ebbbef92c2d3/d24dd229b47946bb8d89c4b98af4e5
> fe/output.shp
> After searching around I've tried updating the directories in GRASS
> options as suggested here:
> https://gis.stackexchange.com/questions/219808/finding-
> grass-module-after-upgrading-qgis-mac
> Still no dice. Now I also get the following error when starting Qgis:
> GRASS init error: GRASS was not found in '/Applications/QGIS
> 3.app/Contents/MacOS/grass7' (GISBASE), provider and plugin will not work.
> Any ideas?
> Thanks in advance. Otherwise, this is way better than my old ArcGIS
> packages.
> Qgis-user mailing list
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the
> past isn't a fiction designed to account for the discrepancy between my
> immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180319/c6b39ee4/attachment.html>
