[Qgis-user] QGIS3 Processing Clip
DelazJ delazj at gmail.com
Fri Mar 23 03:54:04 PDT 2018
See Settings --> Options --> Processing --> General menu.
HTH,
Harrissou
2018-03-23 11:30 GMT+01:00 Drexel Peter <Peter.Drexel at vorarlberg.at>:
> Hi all,
> In QGIS 3.0 I use native:clip in processing to clip a Shapefile with
> another shapefile.
> The Import-Shapefile contains some invalid polygons so I get an error
> ________
> Processing algorithm…
> AlgorithmDialog
> Input parameters:
> { 'INPUT' : 'V:/Geodaten/Wasser/Einzugsgebiete/Vlbg_Umgebung/
> Einzugsgebiete_FGW/ezg_gesamt1_bearbeitet_3D_name.shp', 'OVERLAY' :
> 'C:/temp/QGIS3/Clip-Maske.shp', 'OUTPUT' : 'memory:' }
> Feature (0) has invalid geometry. Please fix the geometry or change the
> Processing setting to the "Ignore invalid input features" option.
> Execution failed after 0.35 seconds
> Loading resulting layers
> Algorithm 'Clip' finished
> ______________
> In the Log-section of the Clip-Tool.
> But where can change the setting to “Ignore invalid input features”?
> Thanks
> Peter
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180323/7dfcc466/attachment.html>
