[Qgis-user] mac qgis3 binary errors
Adam Dershowitz
dersh at alum.mit.edu
Thu May 3 09:01:49 PDT 2018
Ooops. My mistake. I didn’t read your instructions carefully enough. After reinstalling, with pip, I then had not reinstalled qgis. I did that, and now it does open correctly.
Thanks much for the help!
--Adam
> On May 3, 2018, at 11:58 AM, Adam Dershowitz <dersh at alum.mit.edu> wrote:
> I think that is the problem. Towards the bottom of my original email I mentioned that I had only installed python3.6 (from the official source) but not the other options (GUI, command line, pip etc). I had not realized that any of those were necessary. I’ll try to reinstall python with pip, then reinstall gdal, and see how that goes….
> Interesting. Now, instead of 4 different error boxes on startup, I just get two:
> Couldn't load plugin 'processing'
> ModuleNotFoundError: No module named 'psycopg2'
> and
> Couldn't load plugin 'MetaSearch' due to an error when calling its classFactory() method
> ModuleNotFoundError: No module named 'owslib'
> Perhaps there is some other piece missing as well? Do either of those core plugins require the python UNIX command line, or GUI stuff?
> So, making some progress…
> thanks,
> --Adam
>> On May 3, 2018, at 11:48 AM, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>> That's strange. There should be many folders there, for osgeo and all the other stuff QGIS needs.
>> Another possibility is you are missing pip. it's an install option for python 3, normally installed by default but maybe you turned it off?
>> You can check in a Terminal with
>> type pip3
>> If found, the path should be in /library/frameworks/python.framework/versions/3.6. If not found, try reinstalling python 3 and use the default install, then reinstall GDAL and QGIS.
>> And, just checking, but how did you install Python 3? The "official" package from python.org <http://python.org/>?
>>> On May 3, 2018, at 10:35 AM, Adam Dershowitz <dersh at alum.mit.edu <mailto:dersh at alum.mit.edu>> wrote:
>>> No. All that is in there is README.txt ;-(
>>> --Adam
>>>> On May 3, 2018, at 11:16 AM, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>>>> Is there an "osgeo" folder in /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages ?
>>>>> On May 3, 2018, at 10:03 AM, Adam Dershowitz <dersh at alum.mit.edu <mailto:dersh at alum.mit.edu>> wrote:
>>>>> Thanks.
>>>>> I just tried to install gdal, then reran qgis3 and got the same errors, so that didn’t help.
>>>>> --Adam
>>>>>> On May 3, 2018, at 10:56 AM, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>>>>>> You must make sure that that python 3 is installed before installing GDAL Complete. Reinstall GDAL and it should work.
>>>>>>> On May 3, 2018, at 9:53 AM, Adam Dershowitz <dersh at alum.mit.edu <mailto:dersh at alum.mit.edu>> wrote:
>>>>>>> I downloaded the mac qgis3 binary. I also installed the official python 3.6. Whenever I first launch qgis I get a series of errors that pop up and look like this:
>>>>>>> Couldn't load plugin 'FreehandRasterGeoreferencer' due to an error when calling its classFactory() method
>>>>>>> ModuleNotFoundError: No module named 'osgeo'
>>>>>>> Traceback (most recent call last):
>>>>>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 336, in startPlugin
>>>>>>> plugins[packageName] = package.classFactory(iface)
>>>>>>> File "/Users/adershowitz/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/FreehandRasterGeoreferencer/__init__.py", line 24, in classFactory
>>>>>>> from .freehandrastergeoreferencer import FreehandRasterGeoreferencer
>>>>>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in _import
>>>>>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>>>> File "/Users/adershowitz/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/FreehandRasterGeoreferencer/freehandrastergeoreferencer.py", line 20, in
>>>>>>> from .freehandrastergeoreferencer_layer import (
>>>>>>> File "/Users/adershowitz/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/FreehandRasterGeoreferencer/freehandrastergeoreferencer_layer.py", line 16, in
>>>>>>> from osgeo import gdal
>>>>>>> Python version: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 03:03:55) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
>>>>>>> QGIS version: 3.0.2-Girona Girona, exported
>>>>>>> Python Path:
>>>>>>> /Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins
>>>>>>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
>>>>>>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
>>>>>>> Then three more:
>>>>>>> Couldn't load plugin 'profiletool' due to an error when calling its classFactory() method
>>>>>>> ModuleNotFoundError: No module named 'numpy'
>>>>>>> Is there something that is missing. I had tried to use the macports version of qgis3, and didn’t see these errors (although I did get other errors). Then, once I close each dialog box, it opens and works. But, the vector and raster menus don’t show many entries (while they did with the macports version).
>>>>>>> When I installed python 3.6, I only installed the framework. I didn’t include the optional installs such as: GUI applications, command line tools, documentation, shell profile updater, or pip. Could that be causing the problem? If not, is there something else about plugins that I have to fix?
>>>>>>> --Adam
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
>>>>>> "We can die but once, and that once we must die. To be always fearing, then, would not avert it, and would make life miserable."
>>>>>> - Tarzan, on death
>>>> All generalizations are dangerous, even this one.
>> Earth: "Mostly harmless"
>> - revised entry in the HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180503/5890acc8/attachment.html>
