[Qgis-user] Road network download
Xristos Xristoou
saxri89 at gmail.com
Fri May 4 12:22:11 PDT 2018
Thank you! How to do that ? Pre processing?
Στις Παρ, 4 Μαΐ 2018 - 22:19 ο χρήστης Etienne Trimaille <
etienne.trimaille at gmail.com> έγραψε:
> Values are written in the link I put about -1, 1, yes. Often, with OSM
> data, you need some pre-processing to clean all these values. It's based on
> the direction of the line.
> Maybe shapefiles from geofabrik are cleaner?
> 2018-05-04 13:24 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
>> I have oneway field with value -1,1,yes and no .but that values is in
>> lines and i cant understand connections for oneways
>> Στις Παρ, 4 Μαΐ 2018 - 20:19 ο χρήστης Etienne Trimaille <
>>> Sorry, I fail to understand. With OSM data in QGIS, you have the
>>> 'oneway' column in the attribute table. If the field is empty, it means
>>> either OSM doesn't have data for that road or by default it's not oneway.
>>> https://wiki.openstreetmap.org/wiki/Key:oneway oneway=no is the default
>>> so OSM contributors let this field empty. (only to avoid a confusion in
>>> some areas).
>>> 2018-05-04 13:10 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
>>>> Hello
>>>> I need to download road network to used for travel problems.
>>>> In that road i need to have details for oneways connections.
>>>> I try to use OSM download QGIS plugin to take the roads but that data
>>>> dont have direction details for oneway road connections.
>>>> Any idea ?
>>>> Thank you
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180504/947cb0f7/attachment.html>
