[Qgis-user] Road network download
Xristos Xristoou
saxri89 at gmail.com
Fri May 4 13:33:50 PDT 2018
Different arrow for yes and different for no ? And 1,-1?
Στις Παρ, 4 Μαΐ 2018 - 22:27 ο χρήστης Etienne Trimaille <
etienne.trimaille at gmail.com> έγραψε:
> For instance, you can use the field calculator to clean some values in the
> 'oneway' column.
> You can also display an arrow on the line if the field oneway=yes
> 2018-05-04 15:22 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
>> Thank you! How to do that ? Pre processing?
>> Στις Παρ, 4 Μαΐ 2018 - 22:19 ο χρήστης Etienne Trimaille <
>>> Values are written in the link I put about -1, 1, yes. Often, with OSM
>>> data, you need some pre-processing to clean all these values. It's based on
>>> the direction of the line.
>>> Maybe shapefiles from geofabrik are cleaner?
>>> 2018-05-04 13:24 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
>>>> I have oneway field with value -1,1,yes and no .but that values is in
>>>> lines and i cant understand connections for oneways
>>>> Στις Παρ, 4 Μαΐ 2018 - 20:19 ο χρήστης Etienne Trimaille <
>>>>> Sorry, I fail to understand. With OSM data in QGIS, you have the
>>>>> 'oneway' column in the attribute table. If the field is empty, it means
>>>>> either OSM doesn't have data for that road or by default it's not oneway.
>>>>> https://wiki.openstreetmap.org/wiki/Key:oneway oneway=no is the
>>>>> default so OSM contributors let this field empty. (only to avoid a
>>>>> confusion in some areas).
>>>>> 2018-05-04 13:10 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
>>>>>> Hello
>>>>>> I need to download road network to used for travel problems.
>>>>>> In that road i need to have details for oneways connections.
>>>>>> I try to use OSM download QGIS plugin to take the roads but that data
>>>>>> dont have direction details for oneway road connections.
>>>>>> Any idea ?
>>>>>> Thank you
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180504/fc9d05ad/attachment.html>
