[Qgis-user] proj on Windows: mini howto for Cygwin
Jürgen E. Fischer
jef at norbit.de
Sat May 5 11:38:33 PDT 2018
Hi Richard,
On Sat, 05. May 2018 at 15:16:45 +0200, Richard Duivenvoorde wrote:
> Does this break other packages?
No - at least not outside of cygwin.
> If not you could try to do a FeatureRequest in the osgeo4w issue tracker:
> https://trac.osgeo.org/osgeo4w
Should be already there - I think.
proj 5 is already in osgeo4w as test package - but not in the latest release
and not including the updated proj-datumgrid - so not in a good state.
But the default package is still proj 4 and everything is build with that.
My time is currently a bit limited and there are a bunch of other updates
pending. I'm considering whether I can find the spare time to do it, launch a
crowd funding campaign or make it a grant proposal: It's proj 5.0.1 (with a
patch & datumgrid), GEOS 3.6.2, GDAL 2.3, Python 2.7.14 (for QGIS 2.18; pip
doesn't work anymore) and Qt 5.10 (with qca, QtWebKit, QScintilla, qtkeychain,
sip & PyQt5, Qwt/PyQwt and a new gpsbabel) - and possibly other stuff that pops
up on the way.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180505/38c82905/attachment.sig>
