[Qgis-user] Problem with "non valid geometry"
Philip Barlow
philipb at pembrokeshirecoast.org.uk
Wed May 9 06:25:37 PDT 2018
Hi Boris,
You could try the old buffer by zero trick if its self-intersections you are having a problem with.
Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Kirk Schmidt
Sent: 09 May 2018 13:45
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Problem with "non valid geometry"
Hi Boris:
You can use the grass modules under processing toolbox>Grass GIS 7 commands>Vector>v.build.check or v.clean to isolate the problem. Typically it is a polygons with and intersecting sliver that creates the problem.
Kirk
On 5/9/2018 9:35 AM, boris diaz wrote:
Hi there, I´m trying to cut a raster with a polygon mask in qgis 2.18
The validation tool produces a draw with the message "valid output", but the topology tool finds a "non valid geometry" in the id objetc 0. The shape has only one object, an irregular polygon representing a watershed. SO the error shows the entire watershed.
Anyone can help me finding the real error and how can i repair it?
Thanks. Boris
Boris G. DIAZ - Mg.Sci.Ing. Forestal
Área Recursos Hídricos - INTA EEA Santa Cruz
Unidad Académica Río Gallegos (UNPA)
https://www.facebook.com/aguapatagonia/<http://santacruzhidro.blogspot.com.ar/>
www.researchgate.net<http://www.researchgate.net>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com<mailto:kirk at nortekresources.com>
Web: www.nortekreources.com<http://www.nortekreources.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180509/0928a5f9/attachment.html>
