[Qgis-user] Problem georeferencing images in UTM
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu May 17 14:24:45 PDT 2018
I am looking at your maps now. If I understand, it works with lat long but not the UTM Coordinates. It could be a mistake in the utm grid. Perhaps one utm grid is in NAD27 and the other in NAD83. That could explain the shift.
I will look at it.
Nicolas
> Le 17 mai 2018 à 12:42, Carlos Henrique Grohmann de Carvalho <carlos.grohmann at gmail.com> a écrit :
> Thanks Nicolas, but the misalignment still persists. OTF is off, project has same CRS as data (epsg 29192). There is a ~400m difference in the N-S direction.
> Carlos
>> On Thu, May 17, 2018 at 1:28 PM, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
>> Hi,
>> Disable projection on the fly. Make sure the project is in the same CRS as your maps.
>> Nicolas
>>> Le 17 mai 2018 à 12:14, Carlos Henrique Grohmann de Carvalho <carlos.grohmann at gmail.com> a écrit :
>>> Hello all
>>> I have two pngs of topographic maps from southeastern Brazil (a zip file with images and points is available here: https://www.dropbox.com/s/mexeh4be46pgsk6/images_georef.zip?dl=0)
>>> I'm trying to georeference them, but with partial success only. In this image (https://www.dropbox.com/s/37xxqp4fkwpdyqh/utm_error.png?dl=0) you can see that the X coordinate is fine, but the Y coordinate of the two maps won't match.
>>> Both maps use South American Datum 1969. I selected points near the edges, and used the UTM values.
>>> Interestingly, if I use Lat/Long, and place the points at the corners, using decimal degrees, the maps align perfectly.
>>> Any help is appreciated
>>> Prof. Carlos Henrique Grohmann
>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>> http://carlosgrohmann.com
>>> http://orcid.org/0000-0001-5073-5572
>>> ________________
>>> Can’t stop the signal.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> ________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180517/0b877737/attachment.html>
