[Qgis-user] results Measure Tool vs. length()
    Julien Guilloux
    julien.guilloux at ecrins-parcnational.fr
    Fri May 18 06:50:27 PDT 2018
a full Technical description of code 3857 epsg (and his trouble about measurement) here :
https://alastaira.wordpress.com/2011/01/23/the-google-maps-bing-maps-spherical-mercator-projection/
so long...
	Julien-Pierre GUILLOUX
Chargé de mission Eau, Forêt, Natura 2000, coordinateur des porter-à-connaissance
Parc national des Écrins
04 92 40 20 56 / 06 99 77 38 26
[ http://www.ecrins-parcnational.fr/ | www.ecrins-parcnational.fr ]
De: "Julien Guilloux" <julien.guilloux at ecrins-parcnational.fr>
À: "Michel Stuyts" <michel.stuyts at edegem.be>, "Springfield Harrison" <stellargps at gmail.com>, "qgis-user" <qgis-user at lists.osgeo.org>
Envoyé: Vendredi 18 Mai 2018 11:01:04
Objet: Re: [Qgis-user] results Measure Tool vs. length()
Hi Michel,
Never use epsg 3857 for measurement beacuse it is not a "projection"...
this "pseudo projection mercator" 3857, called often "Popular Visualisation" is pseudo.... Because only use for visualization applications.
example in France : 3200 km for a road for example, instead of 2100 km in a real projection (as local zone UTM or a Lambert projection)
So, you can use qgis, esri, postgis etc... the measurment with 3857 will be always bad, due to a "false" calcul from origine 0,0 (equateur cross greenwich) and "false" ellipoide etc....
best regards,
Julien
have a look on :
http://spatialreference.org/ref/sr-org/6864/
De: "Michel Stuyts" <michel.stuyts at edegem.be>
À: "Springfield Harrison" <stellargps at gmail.com>
Cc: "qgis-user" <qgis-user at lists.osgeo.org>
Envoyé: Vendredi 18 Mai 2018 08:44:01
$length gives the same result as length($geometry)
Michel
Van: Springfield Harrison [mailto:stellargps at gmail.com]
Verzonden: vrijdag 18 mei 2018 2:52
Aan: Michel Stuyts <michel.stuyts at edegem.be>
CC: qgis-user <qgis-user at lists.osgeo.org>
Onderwerp: Re: [Qgis-user] results Measure Tool vs. length()
Interesting and alarming observation.
And how do those results compare with output from the $length variable?
Cheers . . . . . Springfield
Samsung Tab 4
On May 17, 2018 5:26 AM, "Michel Stuyts" < [ mailto:michel.stuyts at edegem.be | michel.stuyts at edegem.be ] > wrote:
In the length() function QGIS uses the CRS unit of the layer to calculate the result. When I use for example a layer in a local CRS like EPSG:31370 or EPSG:5439 and a layer in EPSG:3857 (that all use meters as unit) the results are very different (+40% difference). Changing the project CRS makes no difference. When I check the length using the Measure Tool the results are very similar to the local CRS.
How can I measure the length of a line and use it as a label independent from the layer CRS and get results similar to the results of the Measure Tool?
Michel
Qgis-user mailing list
[ mailto:Qgis-user at lists.osgeo.org | Qgis-user at lists.osgeo.org ]
List info: [ https://lists.osgeo.org/mailman/listinfo/qgis-user |
https://lists.osgeo.org/mailman/listinfo/qgis-user ]
Unsubscribe: [ https://lists.osgeo.org/mailman/listinfo/qgis-user |
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180518/51bf557f/attachment.html>
