[Qgis-user] QGIS 3 clipping raster with a polygon - problem
David Addy davesgrandad at gmail.com
Sun May 20 12:15:23 PDT 2018
I have always been able to clip a raster using the mask made by drawing a
polygon around the required area in QGIS 2. However, in QGIS 3 the process
does not work the same way. I cannot figure out how to make a new output
file, and whatever I try results in no comprehensible output.
I have just successfully made a clipped geotiff using 2.18.16, but it would
be better to be able to do it just as easily in Q3.
Can anyone explain what is going on with Raster-Extract-Clipper in Q3?
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
