[Qgis-user] QGIS 3 clipping raster with a polygon - problem
Nyall Dawson nyall.dawson at gmail.com
Wed May 23 15:57:38 PDT 2018
On 24 May 2018 at 01:12, David Addy <davesgrandad at gmail.com> wrote:
> I have had another go with another dataset.
> I have tried both these algorithms in QGIS 3.0.2:
> 1.      Gdal ->" Raster extraction" -> "Clip raster by mask layer"
> 2.      Saga -> "Vector <-> raster" -> "Clip raster with polygon"
> Both give an error message.
> In the case of GDAL it is :"GDAL command output:
> ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in TIFF
> format."
> I must be completely misunderstanding both these processes.
> By reverting to QGIS 2.18.16 the GDAL algorithm works quite happily on the
> same geotiff using the same shp file polygon to clip it..
> In Q3 I do not understand why the output file entry box is labelled
> Clipped(mask) and the box contains (save to temporary file)
> Are there some other entries I need to make it work?
Hi David,
In  both 2.18 and 3.0 you can see the GDAL command which is run by the
algorithm. Can you see if there's any difference between the two? Can
you please share them?
Cheers,
Nyall
