[Qgis-user] GEOS-Verarbeitungsfehler: Ein oder mehrere Eingabeobjekte haben ungültige Geometrien.
Andreas Sauter
sauter at forstlabor.de
Sun May 27 23:10:50 PDT 2018
In my case its not about the styles. tried it in a whole new projekt
with default styles and it didnt worked as well.
regargs
Andreas
INGENIEURBÜRO HOMBURGER
www.forstlabor.de
Telefon: 07733 982588
Telefax: 07733 982589
Lupfenstr. 8
78234 Engen
Am 25.05.2018 um 18:17 schrieb Luigi Pirelli:
> We faced the problem and was related with geometry generation
> necessary to place labels or other symbology elements. Nothing that
> was possibile to (always) workaround
> nyall already fixed in master to avoid this log messages in this
> particular case. Sometimes it really slow down the rendering.
> here the discussion:
> http://osgeo-org.1560.x6.nabble.com/Re-Strange-style-rendering-GEOS-errors-can-you-confirm-td5362500.html
> can you check if changing syle remove the geos errors?
> regards
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> 2018-05-25 17:18 GMT+02:00 Andreas Sauter <sauter at forstlabor.de
> <mailto:sauter at forstlabor.de>>:
> Hi Guys, In the current version 2.18.20 I often have the problem
> that the following error message appears when intersecting two
> shapes: GEOS processing error: One or more input objects have
> invalid geometries. Even after intensive review, no geometry
> errors could be found. This would also be very unusual, because
> the same geometries have always been smoothly intersected in the
> last three years in all previous QGIS versions ... Can you help
> me? Best regards Andreas
> Hallo Leute,
> bei der aktuellen Version 2.18.20 habe ich häufiger das problem,
> dass beim Verschnitt zweier Shapes folgende Fehlermeldung
> erscheint: GEOS-Verarbeitungsfehler: Ein oder mehrere
> Auch nach intensiver Überprüfung konnten keine Geometriefehler
> gefunden werden. Wäre auch ungewöhnlich, da die selben Geometrien
> in allen vorherigen QGIS-Versionen in den letzten drei Jahren
> immer reibungslos verschnitten werden konnten...
> Könnt ihr mir helfen?
> Viele Grüße
> Andreas
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180528/7859711e/attachment.html>
