[Qgis-user] Outline: Marker line with Rectangle Symbol arround a Polygon
    Bernd Laskowski
    bernd.laskowski at reichshof.de
    Mon May 28 05:01:48 PDT 2018
Line offset doesn't solve the Problem,
I use a rectangle symbol along the polygon outline as Marker Line an map
units (zoomable Symbols)
size 3
rotation 90
interval 10
At some edges the rectangles are longer than the border of the polygon.
Regards
bernd
Am 28.05.2018 um 12:42 schrieb Fuenfer-Koenigstein.Benjamin at swm.de:
> Hi Bernd,
> try to use "Line offset" in Marker Line Menu with a half marker symbol. Does it do what you want to see?
> Regards
> Benjamin
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Bernd Laskowski
> Gesendet: Montag, 28. Mai 2018 10:49
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Outline: Marker line with Rectangle Symbol arround a Polygon
> Hi all,
> we use a Marker Line arround a Polygon.
> The Promblem is:
> At the edges the symbol overlaps the polygon if it beginns at the near
> of the edge.
> Is there a sollution to cut the marker symbol at the border of the polygon?
> Like 'draw line only inside Polygon' (at simple Line)
> Regards Bernd
> Qgis-user mailing list
Gemeinde Reichshof
II/10
Bernd Laskowski
Hauptstraße 12
51580 Reichshof
Tel.: (02296) 801 - 313
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180528/7772f800/attachment.vcf>
