[Qgis-user] Qgis 3 on Arch / Manjaro
Niklas Moran
niklas at niklasmoran.com
Thu May 31 06:00:02 PDT 2018
So, sudo pacman -S python-owslib python-psycopg2
should do it. Then there shouldn't be any problems. If it complains of
files already existing and won't install, check the file with pacman -Qo
to see if a package owns it (probably not) and then remove it. Then
re-run the previous command.
On 05/31/2018 08:05 AM, Patrick Dunford wrote:
> It says these modules are not found
> owslib
> psycopg2
> On 31/05/18 14:05, Niklas Moran wrote:
>> I use QGIS 3.03 on Arch and do not have any problems. I've got testing
>> repo enabled.
>> What missing module errors do you have? I did have a problem a while
>> back with an old version of some library I installed for kde that was
>> no longer needed. Check the aur.archlinux.org's comments under the
>> QGIS package- there is lots of helpful info and you can always post
>> there for help.
> Qgis-user mailing list
