[Qgis-user] Measurement tool
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Fri Nov  2 06:51:42 PDT 2018
Distances depend on the WGS84 ellipsoid.  Some tools don’t take that in consideration.  What tools are you using?
Nicolas
> Le 2 nov. 2018 à 08:36, Josh Hull <josh_hull at live.com> a écrit :
> I'm having problems with the measurement tool. It is giving me an
> inaccurate measurement when I am measuring both area and straight line
> distance. I'm currently running QGIS 3.4 because the problem started in
> 3.2.3 and I thought upgrading might solve the issue. I'm running windows
> 10, 64bit and installed from the standalone installer. I use shape file
> overlays of property lines that have been rock solid for the past couple
> years. When I measure a 40 acre parcel of land with the area measurement
> tool, QGIS tells me the area is over 83 acres. If I measure a straight
> line distance along the side of a known 40 (it should be 1/4 mile), the
> measurement tool shows .368 miles. I haven't made any changes to the CRS
> and its using WGS 84 / Pseudo-Mercator. I primarily use the software for
> maps in north central United States.
> Any help would be awesome.
> Josh Hull
> Hull Forest Products LLC
> 218-349-9266
> www.forest.solutions
> Qgis-user mailing list
