[Qgis-user] Changing data source from Postgis to Geopackage
Alessandro Pasotti
apasotti at gmail.com
Mon Nov 5 08:18:17 PST 2018
On Mon, Nov 5, 2018 at 5:10 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Alessandro,
> Interesting. Deferred handling of bad layers is kind of related, but not
> exactly the same.
> In my case I want to "bulk-change" a lot of layers (60+) from Postgis to
> Geopackage. The data itself is already converted and has exactly the same
> structure. After the data source change I want the data source to be
> permanent in the new project. So it is not just one or two, but a lot of
> layers. Some of them have additional filters, some don't.
> Or - even better - allow to switch back and forth between Postgis and
> Geopackage from within the same project.But
> https://github.com/qgis/QGIS/pull/8359 is already a very good start.
> Would it also handle "bulk" change for all data from the same source?
No, but the API to do that is now in place.
Bulk change is actually something we should eventually implement, both for
the initial handle bad layers and as a standalone utility (the latter could
actually also be a plugin).
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181105/b9f743ce/attachment.html>
