[Qgis-user] Fwd: qgis - v.vol.rst from grass
Francois Chartier
fra.chartier at gmail.com
Sat Nov 10 10:53:01 PST 2018
If it is "just the matter" is it something approachable by non coder person
and how many hrs roughly 10 or 100 hrs of work?
Le lun. 29 oct. 2018 à 04:12, Luigi Pirelli <luipir at gmail.com> a écrit :
> Hi Francois
> is it just matter to create appropriate algorithm descriptop in qgis core?
> e.g. doing a Pull Request (with tsts) to have the algoritym supported?
> This guid sould give you the appropriate hints
> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/grass7.txt
> and obviously all the descriptors available in:
> https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/grass7/description
> this is one of the QGIS part where users can help a lot adding new backend
> algorithms with related tests. To create tests for a not tested algorithms
> please see this guide:
> http://www.opengis.ch/2016/02/04/increasing-the-stability-of-processing-algorithms/
> a TODO list for grass is here:
> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/TODO.md
> regards
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On Sun, 28 Oct 2018 at 16:01, Francois Chartier <fra.chartier at gmail.com>
> wrote:
>> Hi
>> Is the plugin v vol rst available from within qgis? i didnt see it in
>> the list of vector plugin from grass.
>> i am looking for a 3d interpolator and i believe only grass can do this
>> in open source.
>> Are there other plugins that can do 3d interpolation?
>> by 3d i am not referring to interpolation of elevation, but by
>> interpolation of 3d dataset with xyz + attribute (ex: soil moisture), with
>> data points vertically stacked, and would need to interpolate verically and
>> horizontally.
>> thks
>> f
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181110/c4cff3db/attachment.html>
