[Qgis-user] Iterators in QGIS
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Nov 13 05:50:39 PST 2018
I use python and not the modeler but I believe the model, once finished can be run in batch mode like the other processing algorithms.  Others will confirm.  Unless there is very specific manipulations, You should find org2org in processing and  used in batch mode directly.
It can also be used in the command line and iterator can be done there if you use dos iterators.
https://www.gdal.org/ogr2ogr.html
If not I think the gdal plugin in Qgis 2.18 has a option (for many algorithms ) to take all files from one directly and to export them to another. I know they have this for gdal translate so they probably have it for OGR2OGR.  This uses a true iterator so you only have to set things once.  You can run two version of Qgis if you use the OSGeo4w installer.
Nicolas
> Le 13 nov. 2018 à 02:56, Alejandro Chamizo de Castro <alechamizo at gmail.com> a écrit :
> Dear colleagues,
> I'm trying to make a graphical model in QGIS 3.4 to export several shp to a geopackage. I'd like to use an iterator in the graphical modeler, because I'm not very good with python.
> Is possible to use iterators in graphical model in QGIS like other GIS sw does?
> Thanks a lot
> +34 653681823
> www.gisland.es
>                                        	Remitente notificado con
> Mailtrack 13/11/18 8:52:41
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181113/81c2b285/attachment.html>
