[Qgis-user] WMTS fail on loading - QGIS 3.4
Michel Stuyts
michel.stuyts at edegem.be
Fri Nov 16 00:14:05 PST 2018
Did you set your own API token, because the word YOUR_API_TOKEN in the uri in the error suggests you didn't.
Michel
Van: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Namens Ian Reese
Verzonden: vrijdag 16 november 2018 0:30
Aan: qgis-user at lists.osgeo.org
Onderwerp: [Qgis-user] WMTS fail on loading - QGIS 3.4
Hi QGIS
I'm currently using QGIS 3.4, on Windows 7.
I am getting an error when I try to connect to a WMTS layer:
Invalid Layer: Raster layer Provider is not valid (provider: wms, URI: SmoothPixmapTransform=1&contextualWMSLegend=0&crs=EPSG:2193&dpiMode=7&featureCount=10&format=image/png&layers=set-4702&styles=style%3Dauto&tileMatrixSet=EPSG:2193&url=https://data.linz.govt.nz/ services;key=YOUR_API_TOKEN/wmts/1.0.0/set/4702/WMTSCapabilities.xml
The sample WMTS can be accessed here:
https://data.linz.govt.nz/set/4702-nz-aerial-imagery/webservices/
I tested the same WMTS connection using QGIS 2.18, 2.6 and ArcMap also and received no error.
The WMTS connection shows an error no matter what layer I try to access from our data service.
If I use an a connection from outside our data service: https://tiles.maps.linz.io/nz_colour_basemap/WMTSCapabilities.xml, everything works fine
Cheers,
Ian C Reese
Senior Spatial Analyst
Location Information Data Services
E ireese at linz.govt.nz<mailto:ireese at linz.govt.nz> | DDI 04 6504
Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
PO Box 5501, Wellington 6145, New Zealand | T 04 460 0110
W www.linz.govt.nz<http://www.linz.govt.nz/> | www.landonline.govt.nz<http://www.landonline.govt.nz/> | data.linz.govt.nz<http://www.data.linz.govt.nz/>
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz<mailto:info at linz.govt.nz>) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181116/a2d5ca65/attachment.html>
