[Qgis-user] GUI issue of QGIS 3.2.3 on macOS
William Kyngesburye
woklist at kyngchaos.com
Mon Oct 8 17:05:00 PDT 2018
Well, I don't know about "best" solution - a lot of work installing Xcode and compiling everything, and if you have a retina Mac, you'll probably have a major slowdown:
https://issues.qgis.org/issues/19546
That's the main tradeoff - I build with Qt 5.9, which has the small canvas problem (simple workaround), Homebrew uses Qt 5.11 with the retina slowdown problem (no workaround).
> On Oct 8, 2018, at 4:50 PM, ulb <dpeeter1 at ulb.ac.be> wrote:
> Hello,
> This is an issue on Mac since 3.2.1, already discussed ; you may find a workaround here https://issues.qgis.org/issues/19524 <https://issues.qgis.org/issues/19524> .
> The best solution so far is to use the homebrew distribution, see : https://github.com/OSGeo/homebrew-osgeo4mac <https://github.com/OSGeo/homebrew-osgeo4mac>
> HTH
>> Le 8 oct. 2018 à 11:06, PARESH CHAUKHANDE <paresh.chaukhande at gmail.com <mailto:paresh.chaukhande at gmail.com>> a écrit :
>> Hello,
>> I have updated the QGIS version to 3.2.3 on macOS High Sierra. I have found the working window got shrinked (rectangle box like) in the new version.
>> Here I can’t attach the screenshot because of the size issues. Any solution to these technical glitch.
>> Thank you.
>> Sincerely yours,
>> PARESH CHAUKHANDE
>> Scientist,
>> Division of Crop Production,
>> ICAR-CPRI, Shimla. 171 001.
>> Mobile : 07233895266
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181008/66581fdc/attachment.html>
