[Qgis-user] z factor in aspect calculation?
Andrew Harfoot ajph at geodata.soton.ac.uk
Fri Oct 12 02:01:03 PDT 2018
I'd agree, the aspect of a slope does not vary with it's gradient, and
the scale factor is only used to ensure that the gradient calculations
are made using consistent units in XY & Z.
Cheers,
Andy
On 11/10/2018 19:43, Nicolas Cadieux wrote:
> Hi,
> I use a z factor in slope and hill shade calculation when my DEMs are
> in Long/Lat and the altitudes in metres (like SRTM, ASTER GDEM...).
> In GdalDem , there is not a z factor or a scale option for Aspect
> (0-360D azimuth) but in the Qgis terrain analysis, there is. (It does
> not appear to work in Qgis 2.18.24).
> In Qgis 3.2.3, when using the QGIS Terrain analysis Aspect algorithm
> with a z factor of 1, I get identical results as in gdaldem and
> results look and feel good.  I figure it's probably the same algorithm
> running in the background.  What more,   the aspect file is similar to
> result done on a reprojected DEM in a local UTM zone (where no z
> factor is needed as everything is in metres).  Reprojecting is not an
> option for my project.
> In the QGIS Terrain analysis Aspect algorithm, if I use 0.0000126 as
> the correct z factor for the area (1 / The length of a Degree of
> Longitude in metres at a latitude of 45N) (or 1/78847=0.0000126)  my
> results are very wrong.
> I wonder if using a z factor (0.0000126) is not needed for the aspect
> calculation and that this should be removed from the QGIS Terrain
> Analysis aspect options.  Any thoughts?
> Nicolas
> Qgis-user mailing list
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel:  +44 (0)23 8059 2719
www.geodata.soton.ac.uk
