[Qgis-user] clip polygon with raster
DelazJ delazj at gmail.com
Fri Oct 12 02:52:07 PDT 2018
Le ven. 12 oct. 2018 à 11:28, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi
> im trying to do this  ( with clip from vector/ geoprocessing tool , and
> its failing again and again
> im using 2.18.24
> I get messege 'QgsRasterLayer' object has no attribute 'fields' See log
> for more details
All is  said here: it's expecting a layer with fields, which a raster does
not have; it's not intended to work with raster. Please read the help text
in the dialog.
If you want to clip a raster, give a look to the GDAL clip raster by mask
layer (in the Processing toolbox or Raster --> Extraction --> Clipper )
Hope that helps,
Harrissou
is there some help to this?
> thanks
> boaz
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181012/d1e82947/attachment.html>
