[Qgis-user] Scale on printed pdf is incorrect
Antongeo76 antoviscomi at gmail.com
Mon Oct 15 08:19:31 PDT 2018
Hi Flore,
I just did a test on a 1: 2000 scale map I printed from QGIS 2.18.24
in QGIS (whit snap active) the measurement between two points is 67.658 m,
on the pdf the same measurement (without snap) is 33.802mm.
The difference is only 0.027mm and is probably due to the absence of a snap
in the pdf reader.
Regards
Antonio
Flore Cotton wrote
> Hi,
> I have a problem with printing a map on the right scale (Qgis2.18.24).
> If I put the map in the print composer on an A4 format, I change the scale
> (for example 1000), and I print the pdf, it is printed on the right scale.
> (I recalculated it, by measuring a specific distance in qgis and then on
> the pdf).
> Now, our map is very detailled and we need those details in good quality.
> So we need to print the map on format A0, to have the best quality. If I
> do the same as before (change scale, print on pdf), the scale isn't right
> on the pdf. Instead of scale 1/1000, I get some scale in my recalculation.
> Do you know what the problem is, or what did I do wrong?
> Thank you,
> Flore
> Qgis-user mailing list
> Qgis-user at .osgeo
Antonio
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
