[Qgis-user] Very Slow Table Operations in QGIS 3.2.3
    Luigi Pirelli
    luipir at gmail.com
    Tue Oct 16 04:17:15 PDT 2018
nothing related with overflows as described in shown tikets... btw, please
give a check with master (not 2.18) nightly builds e.g. qgis-dev. Fix has
been merged and you can check if it works on on dev version not in 3.2.x.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Tue, 16 Oct 2018 at 13:06, Antongeo76 <antoviscomi at gmail.com> wrote:
> Alessandro Pasotti-2 wrote
> > May be related to https://issues.qgis.org/issues/20094
> > See also: https://github.com/qgis/QGIS/pull/8200
> > On Tue, Oct 16, 2018 at 12:50 PM Antongeo76 <
> > antoviscomi@
> > > wrote:
> >> Hi,
> >> This slowness is also present in QGIS 2.18 as well as in QGIS 3.2.3
> >> and also occurs with fewer features in shapefiles (15000-16000 are
> >> enough),
> >> slowness increases as the number of unsaved editing operations
> increases.
> >> With the "attribute table" opened, even "merge elements" or "split
> >> feature"
> >> operations,
> >> cause some problems (i.e. the counting of the records and the selection
> >> of
> >> the same does not seem synchronized with these editing operations)
> >> and sometimes this cause freeze of QGIS
> >> Antonio
> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> >> _______________________________________________
> >> Qgis-user mailing list
> > Qgis-user at .osgeo
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Alessandro Pasotti
> > w3:   www.itopen.it
> > Qgis-user at .osgeo
> Yes, it can be related but it does not happen only when the "field
> calculator" is used
> it happens even if you perform several 'manual' editing operations and save
> them after about an hour.
> It gives me the feeling that there is a buffer overflow
> Antonio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181016/0ff47838/attachment.html>
