[Qgis-user] OSGeo4W install on Windows Server 2012R2
hugonbg hugonbgg at gmail.com
Wed Oct 17 12:02:49 PDT 2018
Thank you, Antonio!
I found another solution:
I installed "QGIS-OSGeo4W-3.2.3-1-Setup-x86_64.exe" to see if it was not a
problem in Windows 10, it installed and worked perfectly. I checked that in
the bin/ folder there was the zip.dll.
So I installed QGIS 3.2.3 via OSGeo4W and I marked all the packages that
'ZIP' in the name, this way it installed normally and did not display any
errors. Now in Osgeo4w bin folder has a zip.dll.
Regards, Hugo
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
