[Qgis-user] 3d viewer
Andreas Neumann
a.neumann at carto.net
Tue Oct 23 12:51:26 PDT 2018
Hi Ray,
Glad that it worked now.
Yes, 3D is a QGIS 3.x feature only. Also, it is still early stages for
3D in QGIS. I expect several improvements in the upcoming releases.
Note that version 3 can also optionally save in .qgs - .qgz is just a
.qgs in a zip file. But yes, compatibility is only towards a higher
version, not the opposite way.
Greetings,
Andreas
Am 23.10.18 um 21:38 schrieb QGIS.USER:
> Hi Andrea,
> Cracked it but not in a satisfactory manner for me … yet.
> The project file is a V2 (.qgs); in order to get the 3D options, I had
> to “Save As” a V3 project file (.qgz), then close the .qgs project and
> reopen the .qgz project.
> My problem is I am still running V3 & V2 versions on different systems
> (both Windows and Linux) so have keep all my projects as V2 ones to
> ensure compatibility. I have not felt secure enough yet in V3 to
> completely migrate away from V2, and I know that’s my problem, not
> QGIS’s J
> Regards,
> Ray Carpenter
> Chapel Archaeology CIC
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Andreas Neumann
> *Sent:* 23 October 2018 20:17
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] 3d viewer
> Hi,
> Here you can see a screenshot of how it looks at my QGIS copy:
> http://www.carto.net/neumann/temp/layer_properties_3d-view.png
> Right click on the layer in the layer tree --> choose "Properties".
> You really can't see the tab with title "3D View" in your layer
> properties dialogue?
> There are two ways where you have to set your 3D properties:
> 1. Globally: in the 3d view panel (see
> http://www.carto.net/neumann/temp/qgis_global3d_settings.png)
> 2. Per Layer: how to "3D-style" the layer
> Please let us know if this works.
> Theoeretically, it could be that the graphics card of your computer is
> not supported - but since you say that you can run "Arc-Scene" I
> assume your graphics card should be fine ...
> Greetings,
> Andreas
> Am 23.10.18 um 20:45 schrieb QGIS.USER:
> Hi Andreas,
> I wish it were that simple LI have a GeoTiff file containing LiDAR
> (DEM) data that I can manipulate readily in 2D but I cannot find a
> way of displaying in 3D. This option "Layer Properties" --> "3D
> View" does not exist for me. Under “View” I CAN create a “New 3D
> map view” and specify the elevation data (from the same GeoTiff
> file) but I cannot display anything that looks at all 3D. BTW,
> QGIS is 3.2.3 running on Win10 64bit. Am I completely missing some
> option/switch?
> This is particularly annoying as I still have to use (and pay for)
> ESRI’s ArcScene as a way of getting good 3D images of LiDAR data L
> Regards,
> Ray Carpenter
> Behalf Of *Andreas Neumann
> *Sent:* 23 October 2018 18:02
> *To:* Emanuele Mele; qgis-user
> Dear Emanuele,
> You don't need to convert anything. Just go to "Layer Properties"
> --> "3D View" --> checkbox "Enable 3D Renderer" and select your
> basic shape or provide a file with a 3D model (like a tree model,
> car, etc.). There you can also select "Altitude clamping".
> After these settings, it should "just work".
> BTW: don't forget to reply to the "qgis-user at lists.osgeo.org"
> <mailto:qgis-user at lists.osgeo.org> list. Please do not communicate
> with just me, skipping the mailing list.
> Greetings,
> Andreas
> Am 23.10.18 um 15:50 schrieb Emanuele Mele:
> Hi andreas!
> I have converted the point shape to geometry type then set Z
> value and after all I have added geometry attributes.
> xcoord, y coord and zcoord also appear in the attribute table
> but when I enable 3d render doesn't work, they are all flat
> What can I do?
> Thank you!
> Emanuele
> Il mar 23 ott 2018, 11:38 Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> ha scritto:
> Hi Emanuele,
> Points in QGIS3D must be represented by 3d shapes (box,
> sphere, model file, etc.). In each layer there are
> separate styles for 2D and 3D (each one in its own
> separate tab in the layer properties or alternatively in
> the styling panel). Did you use the 3D styles? There you can
> specify the source of the third dimension (z-coordinate or
> terrain, absolute or relative).
> Hope this helps,
> Andreas
> On 2018-10-23 11:13, Emanuele Mele wrote:
> Hi everyone
> I'm trying to plot some point with 3d map in Qgis 3.2 but
> doesn't work.
> I have added the Z but In the 3d plot the point appear at
> the same altitude
> Thank you
> Emanuele
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Unsubscribe:
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181023/2ecafbf7/attachment.html>
