[Qgis-user] Can anyone confirm corrupted QGS-Files?
Luigi Pirelli
luipir at gmail.com
Tue Oct 23 13:42:37 PDT 2018
may you check two things
1) gdal version used in your installation
2) check if you have the same issues using geopackage format (or anything
but shapefile)
try to replicate the same workflow and check if, changing format you have
the same problem.
Because of that points returned, I suspect that is some issue with the
paking procedure of (for some reason) deleted features.
BTW, would be fine to have a replicable procedure that could help
maintainers to narrow the problem.
tnx
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Tue, 23 Oct 2018 at 17:53, Francesco Pelullo <f.pelullo at gmail.com> wrote:
> Hi,
> some days ago me and another person in our office had the same
> problem: lost entities from a shapefile while editing.
> I was editing a puntual shapefile and lost dozen of points, I need to
> digitize them again (and again and again and again...). More or less
> I lost 50 points over a total of 230 points and need to input them
> again, I saved the project and the shapefile at every entity input but
> it was unuseful.
> My collague, instead, was working on a linear shapefile. He lost many
> entities while editing (100 lines over a total of 300), but these
> entities "returns" later and therefore he had two or more duplicated
> entities.
> QGIS 3.2.3 on Win10, project in QGIS 3 format (.qgs). We was working
> on different projects, different shapefiles. Files was archived on a
> network shared directory.
> We switchet to rel 3.2. some days ago and this is the first project
> with new release. Never had these problems with QGIS 2.18.
> Best regards
> Francesco AKA /niubii/
> 2018-10-23 14:10 GMT+02:00, Kai Borgolte <Kai.Borgolte at gmx.de>:
> > Am 19.10.2018 um 09:31 schrieb Kai Borgolte:
> >> today it's the second time my coworker worked on a corrupt QGS file.
> >> Some content like layouts, symbology and labelling are not complete.
> >> Last time he continued to work on the file, and the file size was a
> >> quarter from qgs~. Today he quit QGIS without saving and the file seems
> >> OK, so the corruption seems to introduce at load time.
> >> He is using QGIS 3.2.2 on Windows10.
> >> Does someone else see these problems?
> > today we found the reason: he edited QGIS3-files in QGIS 2. In future je
> > should save QGIS3-projects as .qgz.
> > I had assumed, that QGIS 2 would warn about opening "future" files, but
> > it seems it doesn't?
> > Kai Borgolte, Bonn
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Ciao
> --FP
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181023/16fe644a/attachment-0001.html>
