[Qgis-user] 3d viewer
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Wed Oct 24 07:07:31 PDT 2018
Hi Emanuele, list,
The reason why you won't be able to see your data in 3D map, is because
your data are not 3d!
For Emanuele problem:
- Buildings are not 3d polygons. You can use extrusion and height settings
(if they are available from the attribute table) to fake the 3d buildings.
- Points were not 3d points either. There is an attribute containing Z
value. You can run "Set Z value" function to generate the 3d points using
the Z column.
Once you have done those adjustments, you can create the 3D map.
Hope that helps other. But as Andreas mentioned, 3D is new and we are
aiming to add more features. Please also help with documentation so others
can use the features.
Kind regards
Saber
On Wed, 24 Oct 2018 at 14:16, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi Emanuele,
> Could you send me a link to your data in a private email?
> Regards
> Saber
> On Wed, 24 Oct 2018 at 14:13, Emanuele Mele <emanuele.mele94 at gmail.com>
> wrote:
>> Hi!
>> Here is a screenshot the appearance of the point shape and a DSI model
>> that work correctly in Qgis 3.2:
>> https://postimg.cc/fVZZtrV4
>> What can I do to project point shape with the Z?
>> Emanuele
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Saber Razmjooei
> www.lutraconsulting.co.uk
> +44 (0)7568 129733
Saber Razmjooei
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181024/f6cbb0e9/attachment.html>
