[Qgis-user] how does QGIS generate the EPSG from a Shapefile?
Raymond Nijssen
r.nijssen at terglobo.nl
Thu Oct 25 06:27:56 PDT 2018
As far as I know, qgis cannot discover it. If the shapefile is missing
the projection info, it will either:
1. Ask you to select it
2. Select the one your current map is set to
3. Select a predefined epsg
depending on your settings.
If your settings are 2. or 3. you might not notice this, and think qgis
is selecting the right one for you.
On 25-10-18 14:27, Rodrigo Mariano wrote:
> Hello everyone,
> I would like to know: how does QGIS generate the EPSG from a Shapefile?
> I ask this question, because I'm trying to upload a Shapefile by OGR,
> but the OGR doesn't
> insert the correct EPSG. So I need always open the Shapefile in QGIS to
> discover the
> EPSG before uploading it with OGR.
> Thanks in advance.
> Best Regards,
> Rodrigo
> Qgis-user mailing list
