[Qgis-user] how does QGIS generate the EPSG from a Shapefile?
    Andre Joost
    andre+joost at nurfuerspam.de
    Thu Oct 25 07:12:34 PDT 2018
Am 25.10.18 um 16:00 schrieb ralfwessels:
> Hi Rodrigo,
> Only if the shapefiles contain a prj-file (with the right informations about
> the coordinate system) QGIS opens it automatically correct.
Not necessarily with the correct EPSG code. If there are several EPSG
codes with (almost) similar parameters, QGIS takes the first it finds.
Especially EPSG:3857 is a candidate for false detection.
If the shapefile was created with QGIS, it has a .qpj file with the EPSG
code number stored inside. If the shapefile was created with some other
software, QGIS has to guess.
Greetings,
andre Joost
