[Qgis-user] "Official" QGIS Web Client?
Christopher Gray cgray at graytechsoftware.com
Mon Sep 3 13:12:40 PDT 2018
Andreas,
Thank you for the description, I have taken some more time to look into
both QWC2 and Lizmap. QWC2 seems very nice [although I would like if the
menu remained showing on the larger screens.] I have a tendency to want to
use QWC2 since it is intended to integrate with QGIS projects and appears
to be in development alongside QGIS, but Lizmap is very nice as well.
Do you happen to know if QWC2 has any authentication features yet?
Thank you, Chris
On Mon, Sep 3, 2018 at 4:36 AM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Chris,
> From these three clients you mention, I would currently only consider
> QWC2. It is now in a good state and deployed in several provinces and
> cities as production version. Already now, QWC2 has exceeded the
> functionality of QWC1 and it is based on modern, up-to-date libraries and
> responsive. Also, QWC2 is actively in development.
> The demo application is not because QWC2 is not in production state, but
> it should help you to get a start project.
> QWC1, and I assume EQWC is based on old versions of OpenLayers and not
> fully responsive.
> As Paolo mentioned, there is also Lizmap.
> In your case, I would evaluate QWC2 and Lizmap.
> Greetings,
> Andreas
> On 2018-09-03 04:33, Christopher Gray wrote:
> I've found 3 QGIS related web clients:
> QGIS Web Client (QWC1)
> QGIS Web Client 2 (QWC2)
> Enhanced QGIS Web Client (EQWC)
> The QGIS website still references QWC1, while the QWC1 page says it is no
> longer maintained and suggests QWC2. The QWC2 page lists itself as a "demo
> application" which seems to suggest it is in-progress, but perhaps I am
> misinterpreting this. The EQWC page looks like a functioning option but
> suggests it is based on QWC1 which I understand was considered outdated...
> EQWC seems to perform nicely (based on their demo maps), and has user and
> guest authentication which seems very important for map access.
> Anyhow, which of these is considered the current "QGIS Web Client" / most
> appropriate to use at this time?
> [In my specific situation, this will be my first web-client setup. I'm
> preparing to setup a publicly available map for my town and a private map
> for my family farm in the town (That will require authentication to
> access).]
> Thank you, Chris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180903/507ba55c/attachment.html>
