[Qgis-user] Add new layer to existing GeoPackage file
Lene Fischer
lfi at ign.ku.dk
Tue Sep 4 13:20:26 PDT 2018
OK thanks - Just tried to select/draw if I have 1 layer - same result - but if i have two layers I can select and draw.
Regards
Lene Fischer
Lektor
Københavns Universitet
Institut for Geovidenskab og Naturforvaltning
SKOVSKOLEN
Nødebovej 77a
3480 Fredensborg
DIR 40115084
lfi at ign.ku.dk
-----Oprindelig meddelelse-----
Fra: Nyall Dawson [mailto:nyall.dawson at gmail.com]
Sendt: 4. september 2018 22:13
Til: Lene Fischer
Cc: arni at alta.is; mtreglia at gmail.com; qgis-user
Emne: Re: [Qgis-user] Add new layer to existing GeoPackage file
On Wed, 5 Sep 2018 at 06:06, Lene Fischer <lfi at ign.ku.dk> wrote:
> I have the same issue in QGIS 3.2.2– I can´t Export an open geopackage layer the same Geopackage database… And secondly I can´t select any features in the map view. Program says ‘No active vector layer I have no problem in selecting in the attribute table.
> Can someone confirm this – then I´ll file a ticket.
Both issues are already fixed - just gotta wait for 3.2.3!
Nyall
> Regards
> Lene Fischer
> Associate Professor
> University of Copenhagen
> Department of Geoscience and Natural Resource Management
> Forest and Landscape College
> Nødebovej 77a
> 3480 Fredensborg
> Denmark
> MOB +45 40115084
> lfi at ign.ku.dk
> Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Árni Geirsson
> Sendt: 13. juni 2018 20:12
> Til: mtreglia at gmail.com
> Cc: palousegeo at outlook.com; qgis-user at lists.osgeo.org
> I did not know that it was possible to drag the layer into the browser - that's very handy. But another way is to connect to the geopackage using DB Manager and then upload any additional layers.
> Arni
> Árni Geirsson
> Alta ehf // +354 582 5000 // +354 897 9549
> On Wed, 13 Jun 2018 at 17:37, Michael Treglia <mtreglia at gmail.com> wrote:
> Hi Rick,
> Here's what I've done albeit this isn't as smooth as directly doing "save as" to the gpkg file...:
> Save the file as another file type (or another gpkg file);
> You can then drag layers from the Layers panel to the .gpkg file in the Browser panel.
> I hope that helps!
> Mike
> On Wed, Jun 13, 2018 at 1:25 PM, Rick Rupp <palousegeo at outlook.com> wrote:
> Hi,
> I want to use the “Save as” function on a GeoPackage layer to save a reprojected copy to a new layer in the same GeoPackage file. The function fails with an “Error: Cannot overwrite an OGR layer in place” message. The same thing happens if I try to save a subset of selected features from a layer to the same GeoPackage file. However, if I use the ogr2ogr function it works nicely. Is this the expected behavior? I am updating lab exercises for students in my beginning GIS class, and trying to switch from shapefiles to GeoPackage, so I am reluctant to send students to the command line early in their GIS training. I am working with QGIS 3.0.3 on Windows 10.
> Regards, Richard
> Qgis-user mailing list
