[Qgis-user] QGIS server and pg_service.conf
Andreas Neumann a.neumann at carto.net
Thu Sep 6 11:33:58 PDT 2018
Hi Thomas,
Does it work now?
It might also be a different issue. It might be an authentication issue.
If you used authentication manager and don't store the login and
password in the QGIS project file, there may be issues. In that case you
also have to do something (I don't know exactly what) to enable
authentication manager on QGIS server to read the credentials. I also
wonder how to handle such cases. For that reason, I still store the
login name and password in the qgs project files, instead of using the
authentication manager.
If this is the case, maybe Alessandro can help?
Greetings,
Andreas
Am 06.09.2018 um 15:32 schrieb Etienne Trimaille:
> Either use PGSERVICEFILE or put it
> /etc/postgresql-common/pg_service.conf. It's working well for me with
> QGIS 2.18.23.
> Le jeu. 6 sept. 2018 à 07:55, Jürgen E. Fischer <jef at norbit.de
> <mailto:jef at norbit.de>> a écrit :
>     Hi Thomas,
>     On Thu, 06. Sep 2018 at 13:44:40 +0200, Thomas Schüttenberg wrote:
>     > Yes, I did that. The environment variable PGSYSCONFDIR is set
>     also on the
>     > server machine, it points to the same connection file and it
>     works: QGIS on
>     > the server pc can load layers with this service parameter.
>     PGSERVICEFILE?
>     Jürgen
>     Jürgen E. Fischer           norBIT GmbH             Tel.
>     +49-4931-918175-31
>     Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>     +49-4931-918175-50
>     Software Engineer           D-26506 Norden http://www.norbit.de
>     QGIS release manager (PSC)  Germany                    IRC: jef on
>     FreeNode
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180906/c7892be5/attachment.html>
