[Qgis-user] question about filtering
    Boaz Bar Ilan
    boazprosie at gmail.com
    Wed Sep 12 06:33:18 PDT 2018
Thanks!
בתאריך יום ד׳, 12 בספט׳ 2018, 16:18, מאת DelazJ <delazj at gmail.com>:
> Hi,
> You can simply use a CASE WHEN expression in the field box. Not the same
> example but see
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#define-labels-based-on-expressions
> Regards,
> Harrissou
> Le mer. 12 sept. 2018 à 15:00, Nicolas Cadieux <
> nicolas.cadieux at archeotec.ca> a écrit :
>> This should help.
>> https://youtu.be/0y_Rh4tpYPM
>> https://qgis.org/en/site/forusers/visualchangelog212/index.html?highlight=rule%20based%20labelling#feature-rule-based-labeling
>> Please add the QGIS version and OS you are using if you need more
>> information.
>> Nicolas
>> Le 12 sept. 2018 à 08:37, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
>> hi
>> I choose to show label on every polygon which describe, say , its area.
>> how can I filter , or not to show , values that are out of selected range?
>> what is the tool ?
>> I didn't find any good explanation to rule base labeling in case this is
>> the tool
>> thanks
>> boaz
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180912/989e441f/attachment.html>
