[Qgis-user] Geopagkage and "geom" in DBmanager
Jean-Baptiste Desbas
jb.desbas at gmail.com
Thu Sep 13 04:20:04 PDT 2018
I have to use *st_area(CastAutomagic(geom)) *instead of *st_area(geom)*,
otherwise null column is retourned.
Le jeu. 13 sept. 2018 à 11:45, Bo Victor Thomsen <
bo.victor.thomsen at gmail.com> a écrit :
> Hi Lene -
> I've made a few observations regarding the use of GeoPackage in
> DBManager...
> I have a *GeoPackage* based table called "renhold" containing polygons.
> Primary key column is an integer called "fid" and the geometry column is
> called "geom" - It's pretty close to your setup
> If I use the *DBManager* with the *GeoPackage *dataprovider and execute
> the following statement: *select fid, st_area (geom) from renhold , *it
> returns a table with 2 columns as expected. However , column nr. 2 contains
> only nulls. However, the statement does not result in an error. The
> function "st_area" simply doesn't return a value besides null.
> An now the mystery!! :
> If I use the *DBManager* with the *Virtual Layers -> Project layers *dataprovider
> and execute the following statement: *select fid, st_area (geometry) from
> renhold , *it returns a table with 2 columns as expected. And column nr.
> 2 do contain the expected area values. Go figure...
> NB! The "renhold" layer is visible in the map and named "renhold"
> NBB! In the *Virtual Layers* dataprovider you have to use the standard
> name "geometry" to represent the geometry column - not the real column name
> ("geom" in this case)
> Actually I have a reasonable explanation: The 2 different dataproviders
> uses different internal functions to calculate the area. However the
> function used by the GeoPackage Dataprovider doesn't work !
> Regards
> Bo Victor Thomsen
> LIFA Denamrk
> Den tor. 13. sep. 2018 kl. 09.27 skrev Alexandre Neto <
> senhor.neto at gmail.com>:
>> Hi Lee,
>> Can you try removing the quotation marks around geom?
>> Best wishes,
>> Alex Neto
>> A qui, 13/09/2018, 02:04, Lene Fischer <lfi at ign.ku.dk> escreveu:
>>> Hi,
>>> Trying out a geopackage layer in DBManager asking a simple SQL statement
>>> st_area
>>> But when I try to write a statement like this
>>> SELECT "vandopland".* , st_area("vandopland"."geom") as areal_m2
>>> FROM "vandopland"
>>> "geom" is not found. Suggestions as geomfromexifgpsblob or geomfromfgf
>>> or geomfromwkb . Then I get "an error occured"
>>> Any suggestions what I might have done wrong.
>>> Regards from a newbee Geopagkace/DBmanager
>>> Lene Fischer
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
> Med venlig hilsen
> Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180913/d99dca16/attachment.html>
