[Qgis-user] changing polygon to point
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Sep 16 08:42:57 PDT 2018
Another solution is to extract the nodes from the polygons (vector menu in 2x). That will give you a point outline of the polygons. It depends on what you want to do. Zoltan’s solution is most likely the one you are looking for.
Nicolas
> Le 16 sept. 2018 à 10:59, Siki Zoltan <siki at agt.bme.hu> a écrit :
> Dear Boaz,
> in QGIS 2.x you can use the realcentroid plugin.
> In QGIS 3.x you can use the point on surface from the processing toolbox->vector geometry->point on surface
> Zoltan
>> On Sun, 16 Sep 2018, Boaz Bar Ilan wrote:
>> hi
>> I have a layer of polygons and I want to convert every polygon to be a
>> point type
>> is there a way to do that ?
>> thanks
>> boaz
> Qgis-user mailing list
