[Qgis-user] error loading SACP into Mac QGIS 3.2.3
William Kyngesburye
woklist at kyngchaos.com
Mon Sep 24 16:21:27 PDT 2018
Looks like a problem with the latest matplotlib 3.0. I had no problems with 2.2.0, that I had installed a while back, it created the fontlist-v300.json as it should. But once I updated matplotlib to 3.0 and deleted the fontlist-v300.json, I got the same error.
3.0 in very new, released 7 days ago. 2.2.x is their long term support version.
Try installing a pre-3.0 version. This should do it (and uninstall 3.0):
sudo pip3 install -U "matplotlib<3.0"
> On Sep 24, 2018, at 10:36 AM, William G. Guthe <wguthe at Princeton.EDU> wrote:
> Hi,
> I have installed QGIS 3.2.3 on an old Mac Pro running El Capitan. I installed Python 3.6 from python.org <http://python.org/>, the GDAL and then QGIS itself. I used pip3 to install matplotlib, scipy, and numpy. I’ve also prepended the paths to 3.6/bin and GDAL 2.2. When I try to load the Semi-Automatic Classification Plugin, I get an error about fontlist-v300.json not being available (which is true, it isn’t there).
> I just met with a student running High Sierra, who gets a similar error about fontlist-v300.json being absent. She has followed the directions for installing 3.2.3, set up the paths correctly, and installed the other packages.
> I’m attaching the entire error message, in case there is more in that.
> Thanks for any help on this.
> Bill Guthe
> Research Computing/OIT
> Princeton University
> Princeton, NJ
> Error message:
> Couldn't load plugin 'SemiAutomaticClassificationPlugin' due to an error when calling its classFactory() method
> OSError: [Errno 62] Too many levels of symbolic links: 'Applications/DivX Player.app/Contents/Frameworks/DPXLibrary.framework/Versions/Current/A'
> Traceback (most recent call last):
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 1353, in
> fontManager = json_load(_fmcache)
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 888, in json_load
> with open(filename, 'r') as fh:
> FileNotFoundError: [Errno 2] No such file or directory: '/Users/wguthe/.matplotlib/fontlist-v300.json'
> During handling of the above exception, another exception occurred:
> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 337, in startPlugin
> plugins[packageName] = package.classFactory(iface)
> File "/Users/wguthe/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/__init__.py", line 65, in classFactory
> from .semiautomaticclassificationplugin import SemiAutomaticClassificationPlugin
> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 674, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/Users/wguthe/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/semiautomaticclassificationplugin.py", line 74, in
> from .ui.semiautomaticclassificationplugindialog import SemiAutomaticClassificationPluginDialog
> File "/Users/wguthe/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/ui/semiautomaticclassificationplugindialog.py", line 39, in
> from .ui_semiautomaticclassificationplugin_scatter_plot import Ui_ScatterPlot
> File "/Users/wguthe/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/ui/ui_semiautomaticclassificationplugin_scatter_plot.py", line 453, in
> from .scatterwidget2 import ScatterWidget2
> File "/Users/wguthe/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/ui/scatterwidget2.py", line 44, in
> from matplotlib.backends.backend_qt5agg import FigureCanvasQTAgg as FigCanvas
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/backends/__init__.py", line 9, in
> from matplotlib.backend_bases import _Backend
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/backend_bases.py", line 46, in
> from matplotlib import (
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/textpath.py", line 8, in
> from matplotlib import cbook, dviread, font_manager, rcParams
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 1363, in
> _rebuild()
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 1344, in _rebuild
> fontManager = FontManager()
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 978, in __init__
> ttffiles = findSystemFonts(paths) + findSystemFonts()
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 270, in findSystemFonts
> fontfiles.update(OSXInstalledFonts(fontext=fontext))
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 218, in OSXInstalledFonts
> for directory in directories
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 220, in
> for path in list_fonts(directory, ext)]
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 157, in list_fonts
> for path in filter(Path.is <http://path.is/>_file, Path(directory).glob("**/*.*"))
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/matplotlib/font_manager.py", line 156, in
> return [str(path)
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/pathlib.py", line 1098, in glob
> for p in selector.select_from(self):
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/pathlib.py", line 559, in _select_from
> for starting_point in self._iterate_directories(parent_path, is_dir, scandir):
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/pathlib.py", line 549, in _iterate_directories
> for p in self._iterate_directories(path, is_dir, scandir):
> [Previous line repeated 3 more times]
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/pathlib.py", line 547, in _iterate_directories
> if entry.is_dir() and not entry.is_symlink():
> Python version: 3.6.6 (v3.6.6:4cf1f54eb7, Jun 26 2018, 19:50:54) [GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.57)]
> QGIS version: 3.2.3-Bonn Bonn, exported
> Python Path:
> /Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins
> /Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180924/c6c0b427/attachment.html>
