[Qgis-user] Hot Spot Accumulation
Andrew Harfoot
ajph at geodata.soton.ac.uk
Thu Sep 27 06:42:19 PDT 2018
For circles of a specific size, one per input data point you'll need to
build your own using tools from the Processing toolbox:
1. Use the Buffer tool on the input points to 200m to create the circles
2. Use the Join attributes by location tool to attribute the circles
with counts and / or weighted counts of the input points falling within
each.
Cheers,
Andy
On 27/09/2018 12:53, GILLEN Finbar wrote:
> Hi Nicolas,
> I checked that but it doesn’t create a singular circle for each point.
> In more dense areas it will merge the circles as one.
> I would be looking for an individual circle for each point.
> Regards
> Finbar
> *From:* Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> *Sent:* 27 September 2018 12:51
> *To:* GILLEN Finbar <finbar.gillen at axa.ie>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Hot Spot Accumulation
> Hi,
> I believe heat map will do that. You can use weight from field.
> http://www.qgistutorials.com/fr/docs/creating_heatmaps.html
> Nicolas
> Le 27 sept. 2018 à 07:42, GILLEN Finbar <finbar.gillen at axa.ie
> <mailto:finbar.gillen at axa.ie>> a écrit :
> Hi All,
> Is there a plugin or tool within QGIS that creates a hotspot for
> each individual point in a dataset and assigns a score based on
> the amount of points that fall within a given radius, say 200
> metres (See image below)?
> <image001.png>
> I would be looking to weight the score with a variable within the
> dataset to.
> Regards
> Finbar
> The contents and any attachments of this electronic mail message
> are confidential and intended only for the named addressees.
> Dissemination, forwarding, publication or other use of the message
> or attachments by any unauthorised person is strictly prohibited.
> Unless stated to the contrary, any opinions expressed in this
> message are personal and may not be attributed to AXA Insurance
> dac or any member of the AXA Group of Companies.
> AXA Insurance dac is regulated by the Central Bank of Ireland. For
> business in Northern Ireland, AXA Insurance dac is authorised by
> the Central Bank of Ireland and subject to limited regulation by
> the Financial Conduct Authority. Details about the extent of our
> regulation by the Financial Conduct Authority are available from
> us on request. AXA Insurance dac is a private company limited by
> shares, registered in Ireland number 136155. Registered Office
> Wolfe Tone House, Wolfe Tone Street, Dublin 1.
> "AXA Supporting Road Safety in Ireland"
> Internet e-mails are not necessarily secure. AXA Group does not
> accept responsibility for changes made to this message after it
> was sent. To help promote the use of electronic documents and to
> be kinder to the environment, please consider whether you really
> need to print this
> email.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> The contents and any attachments of this electronic mail message are
> Dissemination, forwarding, publication or other use of the message or
> Unless stated to the contrary, any opinions expressed in this message
> are personal and may not be attributed to AXA Insurance dac or any
> business in Northern Ireland, AXA Insurance dac is authorised by the
> Central Bank of Ireland and subject to limited regulation by the
> regulation by the Financial Conduct Authority are available from us on
> request. AXA Insurance dac is a private company limited by shares,
> registered in Ireland number 136155. Registered Office Wolfe Tone
> Internet e-mails are not necessarily secure. AXA Group does not accept
> responsibility for changes made to this message after it was sent. To
> help promote the use of electronic documents and to be kinder to the
> environment, please consider whether you really need to print this
> email.
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel: +44 (0)23 8059 2719
www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180927/a4994988/attachment-0001.html>
