[Qgis-user] Buffer Algorithm (Buffer distance of output polygon is not equal to the Distance parameter)
Ben Hur Pintor bnhr.dev at gmail.com
Thu Sep 27 08:41:59 PDT 2018
That's odd. I redid the entire thing just now (restarted QGIS, made scratch
point layer, created a 100m buffer) and the values I get are now correct.
Even the area computations were off in the first one but after redoing the
process, everything looks good.
<https://drive.google.com/file/d/1EmWTh3mgyOAvNRUzxMQgxVmMJZqg_-pg/view?usp=drive_web>
Weird. Maybe I missed something during the first one. Hahaha.
Anyway, sorry for bothering you all.
Cheers!
On Thu, Sep 27, 2018 at 11:07 PM DelazJ <delazj at gmail.com> wrote:
> Hi,
> There might be more information in the *Info* drop-down menu. Expand it,
> please.
> Harrissou
> Le jeu. 27 sept. 2018 à 16:55, Ben Hur Pintor <bnhr.dev at gmail.com> a
> écrit :
>> Hi everyone.
>> I apologize if this has been asked before but I would just like to
>> clarify if this is how the buffer algorithm in QGIS should function.
>> *Issue:* The actual distance from the input layer to the buffer polygon
>> created by the Buffer processing tool (and v.buffer) is not equal (only
>> around 80%) to the Distance parameter provided in the said tool.
>> *Example:* My coordinate reference system is WGS84/UTM Zone 51N (EPSG:
>> 32651). I create a 100m buffer around a point but when I measure the
>> resulting circle, its edge is only ~80m from the point (see buffer-point
>> and buffer-point-distance below).
>> <https://drive.google.com/file/d/1SAptLcRKnGVc8zyESkl-sJZ23a5OWEsy/view?usp=drive_web>
>> <https://drive.google.com/file/d/1aQ0mfadGnEzISkPnu-GGX9SUu1GXhGMs/view?usp=drive_web>
>> I create a 50m buffer around a line but when I measure the resulting
>> buffer, its edge is only ~40m from the line (see line-buffer and
>> line-buffer-distance below).
>> <https://drive.google.com/file/d/11cNTRNbHxB3cFCaZEhXDWqKYEdWJX31K/view?usp=drive_web>
>> <https://drive.google.com/file/d/1PGRabSqF-zrOCpAboncQ_yQxx_0ulByN/view?usp=drive_web>
>> Clarifications will be much appreciated. Maybe I just missed some part of
>> the documentation.
>> Thank you.
>> Sincerely,
>> Ben Hur
>> *Ben Hur S. Pintor*
>> bnhr.xyz
>> Consultancy · Training & Support · Development & Innovation
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
*Ben Hur S. Pintor*
bnhr.xyz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180927/094d1350/attachment.html>
