[Qgis-user] Compiling resources qrc
Tyler Veinot tylerkveinot at gmail.com
Mon Apr 1 11:21:45 PDT 2019
Jurgen;
Thanks, I ended up discovering the solution from here;
https://gisforthought.com/updating-a-plugin-from-qgis-2-to-qgis-3/ when I
looked into the bat file a little closer I saw it was calling those
variables you mentioned.
I don't know why they used this compile.bat when it is actually easier to
do it your way.
Thanks for the answer;
TYler
On Mon, Apr 1, 2019 at 2:59 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Tyler,
> On Mon, 01. Apr 2019 at 14:06:23 -0300, Tyler Veinot wrote:
> > Is there a solution to this issue?
> Run call py3_env.bat & call qt5_env.bat upfront.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190401/f3d8d186/attachment.html>
