[Qgis-user] labeling
Stefan Giese
Stefan.Giese at wheregroup.com
Mon Apr 8 23:30:15 PDT 2019
Depends how you connect your fields:
"field1" || ' ' || "field2" -> one line
"field1" || '\n' || "field2" -> two lines
and if you have a '\n' (like in a file path) within your string it would
also results in two lines... then you should escape your backslash with
\\ or use /
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 09.04.2019 um 08:10 schrieb Boaz Bar Ilan:
> hi
> in the label I include 2 fields ( through the expression dialogue )
> one appear above the other
> is there a way to arrange them in one line?
> thanks
> boaz
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/b87990c5/attachment.html>
