[Qgis-user] How to change raster values from another raster
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Apr 10 06:56:31 PDT 2019
If your raster are mutually exclusive (that is nodata value have data in the other raster) your could use gdal_merge found in processing.
Nicolas
> Le 10 avr. 2019 à 07:01, Wouter Impens <wouter.impens at gmail.com> a écrit :
> Hi Vivien,
> The tool ''r.patch'' should do the trick. More info on https://grass.osgeo.org/grass76/manuals/r.patch.html
> Greetings
> Wouter
> Op wo 10 apr. 2019 om 11:55 schreef vivien.mai at hotmail.fr <vivien.mai at hotmail.fr>:
>> Hello everyone,
>> I'm going to introduce myself quickly. I'm a french researcher in Geology
>> and I use a lot Qgis for my work. I don't know if it's the good forum to ask
>> for support on Qgis so tell me if another forum is more appropriate.
>> I have a DEM with a dame lake in the middle. I need to have the topography
>> under the lake level so I built another DEM with the topography under the
>> lake level. This new DEM has the same projection than the first one but not
>> the same resolution.
>> I want to change the elevation values of the fist DEM  using the values of
>> the new DEM. I have already drawn a polygone of the area where I want change
>> the values (the lake).
>> How can I do this? Can I use a raster calculator?
>> Thank you in advance for your answers.
>> Vivien
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190410/c9e357ed/attachment.html>
