[Qgis-user] Batch "ECW creating"
st_kiefer at web.de
st_kiefer at web.de
Tue Apr 16 03:46:13 PDT 2019
you might want to have a look for
https://gdal.org/frmt_gtiff.html
search for "COMPRESS=" and decide which compression mode to use, and further parameter if posiible to control the compression level like for example "JPEG_QUALITY=", to extend the -co parameter.
Cheers.
Stefan
> Piotr Kania <p.kania00 at gmail.com> hat am 16. April 2019 um 12:32 geschrieben:
> Hello!
> I am sorry for asking about sth not connected with qgis...
> I would like to use old FWTools 2.4.7 to convert geotiff's files to ecw format. Right now I use that "command": for %i in ("d:\....\*.tif") do gdal_translate -of ECW -co LARGE_OK=YES "%i" "d:\.....\%~ni.ecw
> Can I add sth to that "command" to achieve better "compression ratio"? Thanks for any response.
> Greetings - Piotrek
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190416/a7179b94/attachment.html>
