[Qgis-user] QGIS-Server GetMap-Request (3.6.0) does not work
    Alessandro Pasotti
    apasotti at gmail.com
    Tue Apr 16 06:57:20 PDT 2019
On Tue, Apr 16, 2019 at 3:51 PM Kai Behncke <Kai.Behncke at ibbenbueren.de>
wrote:
> Dear users,
>  I try to set up a getMap Request to QGIS-Server 3.6.0 on a SUSE LTE
> 15-system.
> The GetCapabilities-Request works well.
> And:
> If I eg put a wrong layer in a getMap-request, the qgis server talks to me:
> <ServiceExceptionReport version="1.3.0"><ServiceException
> code="LayerNotDefined">
> Layer "xyz_4326" does not exist</ServiceException></ServiceExceptionReport>
> ...so far so good.
> but:
> But if I send the (I think) correct request to qgis-server:
> http://myserveraddress/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=7.62,52.22,7.82,52.31
> CRS=EPSG:4326&WIDTH=300&HEIGHT=300&LAYERS=adressen_4326&FORMAT=image/png&Map=/home/blabla/adressen.qgs
> ..the Apache-Server says:
> Server-Error
> Premature end of script headers: qgis_mapserv.fcgi
This usually means that QGIS server crashed, hard to tell why.
> in the qis-server log it looks not so bad:
> 15:39:57 INFO Server[10612]: Server initialized
> 15:39:57 INFO
> /home/abuild/rpmbuild/BUILD/qgis-3.6.0/src/server/qgsserverplugins.cpp[10612]:
> load library /usr/lib64/qgispython (3.6.0)
> 15:39:57 INFO
> Python support library loaded successfully.
> 15:39:57 INFO Server[10612]: No server python plugins are available
> 15:39:57 INFO Server[10612]: ******************** New request
> 15:39:57 INFO Server[10612]: SERVER_NAME: gisground2.ibbenbueren.intern
> 15:39:57 INFO Server[10612]: REQUEST_URI:
> /cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=7.62,52.22,7.82,52.31&CRS=EPSG:4326&WIDTH=300&HEIGHT=300&LAYERS=adressen_4326&FORMAT=image/jpeg&Map=/home/kai/adressen.qgs
> 15:39:57 INFO Server[10612]: REMOTE_ADDR: 10.45.30.117
> 15:39:57 INFO Server[10612]: HTTP_USER_AGENT: Mozilla/5.0 (Windows NT 6.1;
> WOW64; rv:60.0) Gecko/20100101 Firefox/60.0
> 15:39:57 WARNING [10612]: formatString is: image/jpeg
> 15:39:57 INFO Server[10612]: BBOX:7.62,52.22,7.82,52.31
> 15:39:57 INFO Server[10612]: CRS:EPSG:4326
> 15:39:57 INFO Server[10612]: FORMAT:image/jpeg
> 15:39:57 INFO Server[10612]: HEIGHT:300
> 15:39:57 INFO Server[10612]: LAYERS:adressen_4326
> 15:39:57 INFO Server[10612]: MAP:/home/kai/adressen.qgs
> 15:39:57 INFO Server[10612]: REQUEST:GetMap
> 15:39:57 INFO Server[10612]: SERVICE:WMS
> 15:39:57 INFO Server[10612]: VERSION:1.3.0
> 15:39:57 INFO Server[10612]: WIDTH:300
> 15:39:57 INFO Server[10612]: WMS Request parameters:
> 15:39:57 INFO Server[10612]:  - CRS : EPSG:4326
> 15:39:57 INFO Server[10612]:  - WIDTH : 300
> 15:39:57 INFO Server[10612]:  - HEIGHT : 300
> 15:39:57 INFO Server[10612]:  - BBOX : 7.62,52.22,7.82,52.31
> 15:39:57 INFO Server[10612]:  - LAYERS : adressen_4326
> 15:39:57 INFO Server[10612]:  - FORMAT : image/jpeg
> 15:39:57 INFO Server[10612]:  - VERSION : 1.3.0
> 15:39:57 INFO server[10612]: Parallel rendering deactivated
> Has anybody an idea what is going wrong? Might it be a problem with the
> output of an image?
No idea, sorry, you may try to increase logging level btw (see the docs to
know how).
You can also try to ssh into the machine and run qgis_server.fcgi directly
passing QUERY_STRING in the environement.
Hope that helps.
> Thank you in advance, Kai
> Mit freundlichen Grüßen
> Im Auftrag
> Kai Behncke
> Geoinformation
> Tel.: +49 5451 931-7125
> E-Mail: kai.behncke at ibbenbueren.de
> Rathaus II
> Roncallistraße 3-5
> 1. Stock, Raum 105
> 49477 Ibbenbüren
> Qgis-user mailing list
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190416/511157f9/attachment.html>
