[Qgis-user] Install QGIS 3.x on Ubuntu16.04
Andre Joost
andre+joost at nurfuerspam.de
Tue Apr 23 02:14:03 PDT 2019
you get stuck because qgis 3.4.6 from qgis.org is built against GRASS
7.6.0 from the ubuntugis-unstable ppa, but that ppa has upgraded to
Grass 7.6.1 in the meantime.
This should be resolved by the next QGIS point release.
Alternatively, you can remove the qgis.org stuff from your sources list,
purge and autoremove the 3.4.4 packages, and install QGIS 3.4.6 from the
ubuntugis-unstable ppa only.
HTH,
Andre Joost
Am 23.04.19 um 05:13 schrieb Zhang Qun:
> Hi
> I know Ubuntu16.04 is a bit old for QGIS now but since our software is all
> built on Ubuntu16.04 so I tried to install QGIS 3.x on it. Below is my
> tries but with no luck. Any help?
> *1. using https://qgis.org/ubuntugis <https://qgis.org/ubuntugis>
> repository*
> $ sudo apt install qgis python3-qgis qgis-plugin-grass
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> E: Unable to locate package python3-qgis
> $ sudo apt install qgis python-qgis qgis-plugin-grass
> The following packages have unmet dependencies:
> qgis-plugin-grass : Depends: +grass760 but it is not installable
> E: Unable to correct problems, you have held broken packages.
> *2. using http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
> <http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu>*
> Setting up qgis-providers (3.4.6+dfsg-1~xenial1) ...
> /usr/lib/qgis/crssync:
> /usr/local/cuda-8.0/targets/x86_64-linux/lib/libOpenCL.so.1: no version
> information available (required by /usr/lib/libqgis_core.so.3.4.6)
> /usr/lib/qgis/crssync: relocation error: /usr/lib/libqgis_core.so.3.4.6:
> symbol clCreateCommandQueueWithProperties, version OPENCL_2.0 not defined
> in file libOpenCL.so.1 with link time reference
> dpkg: error processing package qgis-providers (--configure):
> subprocess installed post-installation script returned error exit status
> 127
> python-qgis : Depends: python-qgis-common (= 2.18.28+dfsg-1~xenial1) but
> it is not going to be installed
> Best regards,
> Zhang Qun
> Qgis-user mailing list
