[Qgis-user] DB Manager: Different results from query in DB Manager and in Virtual Layer
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Mon Apr 29 06:57:30 PDT 2019
I have a point dataset with nesting boxes (443) and a non-spatial table
from QField where I filled in the already controlled nesting boxes.
Now trying to find out which bixes are still need to be controlled. To
filter the already boxes, I use this query
SELECT "Birdboxes_GTA_20190316".*
FROM "Birdboxes_GTA_20190316"
WHERE EXISTS (SELECT 1 FROM "birdbox_kontrolle" WHERE
"Birdboxes_GTA_20190316"."kasten_nr"= "birdbox_kontrolle"."kastennr")
in DB Manager, this returns the quiet low of 35 matches.
When I now create new Virtual Layer with exact the same query, a point
dataset is produced with the quite resonable amount of 262
Same the other way round: To get those not controlled boxes I use
WHERE NOT EXISTS (SELECT 1 FROM "birdbox_kontrolle" WHERE
which returns 408 rows, but the more resonable number that is produced
with the virtual layer is 181
I'm happy that all my points are generated correctly, but still I'm a
bit concerned that the query result in DB Manager is so awfully wrong.
Is this just due to my poor sql-knowledge or is it a bug?
Cheers,
Bernd
