[Qgis-user] finding the radius of a curve
Andreas Neumann
a.neumann at carto.net
Mon Apr 29 11:55:46 PDT 2019
Hi Cory,
Not if you use a file-format that supports arcs: Geopackage, Postgis,
Interlines, GML. Maybe also FGDB (but not sure if OGR supports curves
for that format).
Greetings,
Andreas
Am 29.04.19 um 18:21 schrieb Cory Albrecht:
> I tried saving a few layers that had arcs and circles (x,y, r coords),
> but QGIS converts each curve to a bunch of straight line segments
> instead of saving them as curves. :-(
> On Mon, Apr 22, 2019 at 3:33 AM McDonaldR <McDonaldR at angus.gov.uk
> <mailto:McDonaldR at angus.gov.uk>> wrote:
> As your data is in PostGIS and assuming that they are arcs (curved
> lines part of a circle) you could use some geometry and spatial
> SQL functions to calculate the radius of any curve knowing the
> coordinates of the end points of the curve.
> To quote the pseudo code on the linked page:
> “To calculate the radius of an arc, take the height -- "H" -- of
> the arc and divide it by two. Call the result "C." Now take the
> width -- "W" -- of the arc and square it by multiplying it by
> itself. Call the result "D." Next multiply height, "H," by eight
> and call this result "E." Divide "D" by "E" and call the result
> "F." The radius of the arc is C plus F.”
> https://sciencing.com/calculate-radius-curve-7804090.html
> Could probably be wrapped in a function and run against any curve.
> Ross
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Cory
> Albrecht
> *Sent:* 19 April 2019 17:08
> *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] finding the radius of a curve
> I'll give it a try. Thanks!
> On Sun, Apr 14, 2019 at 7:52 AM Mike Flannigan <mikeflan at att.net
> <mailto:mikeflan at att.net>> wrote:
> Draw a circle and measure the diameter/radius.
> Maybe use this plugin to create a circle:
> https://plugins.qgis.org/plugins/CADDigitize/
> Mike
> On 4/13/2019 2:00 PM, qgis-user-request at lists.osgeo.org
> <mailto:qgis-user-request at lists.osgeo.org> wrote:
> > Hello all,
> > I'm looking for a way to find the radius of a curve (for
> roads, railyways)
> > in QGIS. If it were a paper map I could do it with a
> drafting compass
> > (calipers to some) and a ruler, but this is a PostGIS layer.
> > Any plugin recommendations or links to a set of steps to
> accomplish this?
> > Thanks in advance!
> This message is strictly confidential. If you have received this
> in error, please inform the sender and remove it from your system.
> If received in error you may not copy, print, forward or use it or
> any attachment in any way. This message is not capable of creating
> a legal contract or a binding representation and does not
> represent the views of Angus Council. Emails may be monitored for
> security and network management reasons.Messages containing
> inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the
> recipient system or data on it by this message or any attachment.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190429/d57dcde3/attachment.html>
